Thread: Join Curtain Walls at Corner
    2006-04
    Baltimore, MD
    380
    Default Join Curtain Walls at Corner
    It's seems as though I'm missing something incredibly obvious here. I have two glazed curtain walls that meet at a corner. I placed a corner mullion, and received the message following message:
    "A Corner Mullion has been placed at the end of a Curtain Wall that is not joined to another Curtain Wall. The angle of the Corner Mullion will default to 90 degrees."
    It's fine that the mullion is at 90 degrees, but I want to do this right. So how do you join two curtain walls? Thanks for your help.
    2004-06
    Memphis TN area
    7,046
    Default Re: Join Curtain Walls at Corner
    Are these automatically embedded curtain walls cutting basic walls? If so, it still does not work correctly when you want the curtain wall to be continuous around a corner.
    If they're just curtain walls by themselves, or if the surrounding walls have edited profiles to make room for the curtain walls, then you just need to select each curtain wall and check the blue grips on the end of each wall. The blue grip must be at the same point for both walls in order for a corner mullion to work properly.
    AERC, PLLC
    Hernando, Mississippi
    2006-04
    Baltimore, MD
    380
    They were just curtain walls by themselves. I have it figured out now. It seems like every time I think I'm doing a good job as a self-taught Revit user I miss something like that. Thanks for your help!
  1. 2014: Curtain Wall Corner Join
    By Hexdown in forum Revit Architecture - General
    Last Post: 2015-02-16, 08:09 AM
  2. Window Join at Corner
    By sjsl in forum Revit Architecture - General
    Last Post: 2009-11-25, 03:39 PM
  3. Wall Join Corner Condition
    By pnelson in forum Revit Architecture - General
    Last Post: 2009-06-04, 08:40 PM
  4. Replies: 0
    Last Post: 2009-01-31, 03:55 PM
  5. Help with corner mullions and curtain walls
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-06-18, 05:11 PM
