Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 51
Thread: Wipeout's in PDF Print All Black
    2006-05
    Default Wipeout's in PDF Print All Black
    I am having problems with Printing pdf that i have made form a AutoCAD.
    I use the "wipeout" command. when I make the pdf it looks fine.
    But when it prints out the area with wipeout around them area black!
    What do I do?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,104
    Default Re: Wipeout's in PDF Print All Black
    Please note I have *moved* this thread from the New Forum Users Forum to this one as I believe it would be better served here.
    Below snippet is from the small print on the Forum General page -
    <snip>
    New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
    </snip>
    Richard
    Forum Moderator
    2002-01
    jUSt Here (a lot)
    9,104
    Have you checked out the 'Similar Threads' section found at the bottom of this page?
    This thread, "Wipeouts in PDF print as Black" may help.
    2004-07
    Detroit Michigan
    2,508
    I have found that older versions of adobe reader tend to show the
    drawings appropriately. Anyone with 5.0 instead of the current release
    can view and print the wipeouts correctly.
    My office findings, maybe a myth?
    2000-10
    59
    I tried looking through the posts and related topics here and ultimately tested creating an EPS file and running through distiller to get PDF. That printed correctly. Same file printed directly to PDF plots with the wipeouts black. That tells me it's an Adobe bug.
    Just one more thing to have do an extra step that shouldn't be needed, boy I have a lot of those every day.
    Using Vanilla AutoCAD R2006, Adobe Standard 6.0
    Earth
    9,805
    Quote Originally Posted by amiller.113952
    What do I do?
    What PDF driver are you using?
    Can you use DWF instead?
    You can print to DWF, then open that and print to PDF
    R.K. McSwain | CAD Panacea |
    2000-10
    59
    Quote Originally Posted by rkmcswain
    I'm using the Adobe Acrobat Standard 6.0 printer driver here. DWF not an option in my case. The places I need to send PDF files require that format.
    Interestingly, tried PDF995 driver and get the same result, black blobs. Leads me to believe that it's genuinly a PDF issue and by going through EPS then Distiller that the EPS output must be correctly handling the wipeout before it passes it to PDF.
    Bruce
    2002-01
    jUSt Here (a lot)
    9,104
    Quote Originally Posted by bhaugi
    Bruce
    I understand that about PDFs as a requirement over the DWF. I haven't been able to move our office toward the DWF format, yet. Still working on it though.
    I believe what R.K. was stating is to use the DWF format to then print to PDF. Not everyone may have Distiller.
    Thanks for pointing out EPS handles the Wipeouts.
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    alright. Dredging up an old topic cuz it's rearing it's ugly head in my face and making me want to punch the innocent monitor.....
    I print to DWF just fine, it's when i print from DWF to PDF in either an Adobe PDF driver, or the CutePDF driver, it rotates the dang sheet within the paper (22x34, which is normally foreign to me), even tho the "preview" was correct! oh, and i'm using the latest Design Review release AFAIK...
    S&D DB Sharing Forum
    2006-10
    Chicagoland
    154
    Quote Originally Posted by amiller.113952 View Post
    What do I do?
    We had this probelm when using Adobe Distiller. If you have the full version of Adobe, install the PDF Writer off the disc. You will have to go into custom install and select it from the list. I do not know why it isn't a default option. We are using Adobe 5.0.
  1. 2014: cannot print PDF in BLACK / WHITE
    By rtbrodie108 in forum AutoCAD LT - General
    Last Post: 2013-08-14, 02:08 PM
  2. Wipeouts in PDF print as Black
    By The VLG in forum AutoCAD Plotting
    Last Post: 2011-12-02, 02:36 PM
  3. Solid filled regions print always black
    By stephanschneller in forum Revit Architecture - General
    Last Post: 2009-11-26, 01:31 PM
  4. Half tone lines print black
    By joelsyndergaard in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-05-08, 11:51 AM
  5. Line color override but still print black
    By ando_mn in forum Revit Architecture - General
    Last Post: 2007-05-10, 02:26 PM
