S&D DB Sharing Forum
No, it actually comes up "Acrobat PDFWriter" in the printer list. I am using it with Land Desktop 2004.
I am using Adobe Acrobat 5.0. Do a custom install and select the PDFWriter.
I have not upgraded because others I have spoken with said there were large format paper size issues. Anyway, this works well.
This will take care of your rotation issue, too. Make sure your landscape/portrait settings in ACAD plot correspond with your landscape/portrait settings in Adobe. Also, hit the view PDF box when you set the PDF file name and you will always see the PDF you just created. This will save headaches later.
I don't think PDF995 resolves the black wipeout issue. However your printer is named may vary (PDFWriter, AdobePDF, whatever), where the difference is whether you plot directly to PDF or go through Distiller. To go through Distiller, you have t plot to Postscript, then run that through Distiller. Going this route vs. plotting to PDF directly seems to work for whatever reason. For the one checking on updates, if you are running Version 5, that is probably just the latest update for that version, Adobe is up to Version 8 now. I'm pretty sure this issue still exists, but haven't tested.
