Thread: Associate a call out Block with a SSM view, before a view is inserted
    2005-12
    Hartford, CT
    394
    Question Associate a call out Block with a SSM view, before a view is inserted
    though sheet set manager I know how to select a view that has already been placed on a sheet and place a call out tag (section, elevation, ect..) for that view. But is it possible to place a callout tag on a drawing before the view for that call out exists, and later associate that block with a view in the sheet set manager.
    Some times I like to place blank section tags and detail call outs on my plans to remind me what areas require sections and or plan details. I would like to be able to use the blank call outs in the drawind and associate them to the views in SSM later on. Currently I erase the blank call outs, and re-insert new ones through SSM.
    Tim Mailloux
    Tecton Architects
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Associate a call out Block with a SSM view, before a view is inserted
    Quote Originally Posted by tim.101799
    Tim Mailloux
    Tecton Architects
    my thought is, 'how do you reference something that doesn't exist'?
    to use your blank callouts, you'd have to re-link the fields. i'd say you're on the right track with starting over when the view becomes available.
    S&D DB Sharing Forum
  1. Call out sheet number on View Lable Title
    By joforman in forum AutoCAD Sheet Set Manager
    Last Post: 2012-01-11, 05:10 PM
  2. Associate viewport to a named custom view
    By aarkeykamal in forum AutoCAD General
    Last Post: 2009-05-29, 11:31 AM
  3. Plan Detail doesn't show in Call Out View???
    By thand in forum Revit Architecture - General
    Last Post: 2008-07-30, 08:13 PM
  4. 3D Plan & Elevation View Call outs & Keynotes
    By William Troeak in forum Revit Architecture - General
    Last Post: 2007-06-15, 12:24 AM
