Hi guys,
I received a few pdf. files with dwgs. that embedded within. Is it possible to convert (or scan) so it became editable?( since drawings show the casting of a objects so it is difficult to work with when they are not to scale).
Hi guys,
You will never get a pdf to be back to the perfect scale that AutoCad creates them in, you can get it close, however, as long as you have the software to do it. The only thing I have found that does this is Adobe Illustrator, which will convert pdf's back to vector format.
is that program an expensive add on or a stand alone to adobe?Originally Posted by carl_hd_collins
Illustator is a separate application from Adobe like Acrobat and Photoshop.
It's not as expensive as Photoshop, but it ain't too cheap neither. Retails from Adobe website at $499, which is £1-38 in English, I think....
Some tips here:Originally Posted by huuthu_nguyen
http://rkmcswain.blogspot.com/2006/0...df-to-dwg.html
R.K. McSwain | CAD Panacea |
CorelDraw can convert pdf to dxf as well, but ghostscript seems to do a much better job.
Last edited by scott.wilcox; 2006-08-02 at 02:13 PM. Reason: clarified initial comment
Hi
Here a few results obtained from a forum search...
Can I insert a PDF document in a 2002 layout?
Importing PDF files
Free PDF to DWG?
PDF to DWG
PDF 2 DWG
Convert a PDF file into CAD file
PDF to DWG!
How do you get a dwg out of a pdf?
Have a good one, Mike
Last edited by Mike.Perry; 2006-08-02 at 01:44 AM. Reason: What is a "search forum", lets try "forum search".
..and if that's not enough to confuse you, here are some more resources
http://groups.google.com/groups?hl=e...ch&sa=N&tab=wg
http://www.caddigest.com/subjects/pd...d_drawings.htm
go to the Web site below to down load free software to convert PDF to DWG
http://www.aidecad.com/
Bi Nguyen
