Thread: railing styles
    2004-06
    3
    Default railing styles
    When trying to insert railing onto a set of stairs in ADT I realized that I was unable to change any of the check boxes, such as "ballister" and "handrail" when inserting. These options are greyed out on all of my rail styles. I only have this problem at work though, and not at home and cannot come up with a solution as to why? Anyone have any ideas as how to get access to these options?
    ACA/AMEP Forum Moderator arcadia_x27's Avatar
    2003-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: railing styles
    At work, are your railing styles kept on the network maybe where you dont possibly have access rights to change them?
    I could stop if I wanted to David Haynes's Avatar
    2003-05
    Seattle, WA
    222
    Railings can not be modified in the properties dialog box. These 'design rules' come directly from the style.
    Go to Format>Style Manager and select the style you are interested in (also here is where you can bring in styles from your content directory). Right-mouse click on the style and choose edit. Here is where the railing, posts, etc can be modified.
    Hope this helps.
    David Haynes, AIA, LEED AP
    Director of Consulting
    Ideate, Inc.
    www.ideateinc.com
    2004-02
    6
    Thumbs up Re: railing styles
    YOU CAN modify the railing in the properties box when adding a railing. In order for you to accomplish this, you first must change the railing style to "allow each railing to vary". Edit the railing style via the style manager, then check the box "allow each railing to vary" in both the rail locations and post locations tabs.
    Mark
    Mark Couture, AIA Allied Member
    Professional Services Manager
    Autodesk Certified Instructor # 00637
    mark.couture@intellicon.com
    Intellicon Solutions, Inc.
    8933 Western Way
    Suite 17
    Jacksonville, FL 32256
    http://www.Intellicon.com
    Tel: 800-327-3035 ext. 124
    Local: 904-363-2223 ext. 124
    Cell: 904-424-2705
    Fax: 904-363-2226
    2004-06
    3
    Mark's post did the trick. Thank all for the responses and help, much appreciated.
  1. Replies: 3
    Last Post: 2007-02-24, 02:50 PM
  2. Sharing standard Dimension styles, text styles, hatch patterns, etc
    By dhavalpatel_us337373 in forum AutoCAD General
    Last Post: 2007-02-02, 07:34 PM
  3. Railing Styles
    By arcadia_x27 in forum ACA General
    Last Post: 2005-12-09, 01:12 PM
