Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
Thread: Is there a way to have the View names of interior elevation tags read the room names?
  1. #21
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Default Re: Is there a way to have the View names of interior elevation tags read the room names?
    Exactly, you will make our interiors girls very happy indeed
  2. #22
    2003-11
    New Zealand
    1,116
    David,
    See if this does it for you. Note new namespace so you can retain the other version if you wish. This needs lots of refactoring but works OK....
    Guy
  3. #23
    2004-07
    Fort Collins, CO
    1,329
    Works great Guy, I appreciate your work on this.
    I really need to learn some programming, are you still using python?
  4. #24
    2007-08
    322
    Is there a way to have the tag read N, E, S, W in plan view? The full view name in plan is just to much information and clutter that only muddys up the drawing.
    I would like the plan to read A101 in the circle, and N, E, S, W for the arrows. At the same time have the sheet read out the entire view name (i.e. Office - 101 North; the current output)
  5. #25
    2003-11
    New Zealand
    1,116
    Quote Originally Posted by kramernicholasm View Post
    Is the standard functionality not enough? Go to the views properties. Under the Indentity group there are 2 properties, "View Name" and "Title On Sheet". If Title on sheet is blank the sheet the view is placed on will take the name from the View Name. But if title on sheet not blank then the view on the sheet uses this string.
    Guy
  6. #26
    2007-08
    322
    Quote Originally Posted by GuyR View Post
    Guy
    I tried that but it doesnt seem to be working. Perhaps I am just doing it the wrong way. However, if I understand correctly then the sheet file that has the callout in it (Floor Plan) would still show the full elevation name and this just allows you to change the name of the view on the interior elevation sheet. I actually would like to do the opposite of that.
    Alternatly could I modify the tag so that the "elevation 1" portion would read inside of the bubble and the arrows would read "1 - a"?
  7. #27
    2003-11
    New Zealand
    1,116
    Your problem is you can't add new parameters to elevation, view, callout tags. So you can only use existing parameters in different ways.
    HTH,
    Guy
  8. #28
    2007-08
    322
    Does this only work for building elevation tags? I tried to use it on interior elevations and it keeps coming up with no elevation tag selected.
  9. #29
    2005-10
    Boulder CO
    97
    Has anyone been able to get this to work in 09? (or even 0
  10. #30
    2004-07
    Fort Collins, CO
    1,329
    Works fine in 08....any chance of updating for 09 Guy?
  1. Revit 2012 can you Delete Unused Room Names & Department Names
    By billy007nh in forum Revit Architecture - General
    Last Post: 2016-11-04, 06:34 PM
  2. Area Tags linked to Room Names
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2004-12-06, 01:33 AM
  3. View Names and Elevation Names not the same.
    By Jason in forum Revit Architecture - General
    Last Post: 2004-05-22, 09:03 PM
