My pull down menus (file, edit, etc.) have gone amiss. Does anyone know how to get them back?
What Program are you using, so I can move this to the proper forum?Originally Posted by joe.szanyi
Hi Joe,
Please note I have *moved* this thread from the Coffee Without Cad forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
Samantha Hally
CWC Forum Moderator
Sounds like your mnu file is not loaded. If you type MENULOAD and hit ENTER, you should see in that dialogue box that appears the file ACAD.MNU (among others anyway). If it is not there, you should load it and everything will appear again. You can find your ACAD.MNU file under C:\Documents and Settings\your username\Application Data\Autodesk\AutoCAD 2005\R1?\enu\Support
(please see attached)
Thanks that worked. It was there so I unloaded it and reloaded it and that solved the problem.
Joe
Glad it worked!
