Thread: AutoCAD 2002 freezes as Windows is preparing to load AutoCAD
    2005-12
    24
    Default AutoCAD 2002 freezes as Windows is preparing to load AutoCAD
    Has anyone experienced Autocad 2002 freeze up during the process:
    Windows is preparing to load Autocad
    What processes does Autocad run in task manager?
    Lance
    2001-12
    St. Louis
    5,408
    Talking Re: AutoCAD 2002 freezes as Windows is preparing to load AutoCAD
    Quote Originally Posted by lance_lie
    Lance
    hello, I'm moving this from the cad management forum to this one, as I believe it will be better served here. Thank you.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    I could stop if I wanted to Ogre's Avatar
    2005-06
    In the end, Cauliflower is just albino Broccoli
    288
    Default Re: AutoCAD 2002 freezes as Windows is preparing to load AutoCAD
    Lance
    I have come to notice that if you end the WsCommCenter.exe process, then you have a lot faster response...I do not remember if they had the Comm Center is ACAD2002 or not, but go ahead and look for it under the Processes....
    13,656
    Question Re: AutoCAD 2002 freezes as Windows is preparing to load AutoCAD
    Hi
    Does this only happen under certain conditions ?
    Has something recently changed ( Hardware / Software ) on your system ?
    Do others in your office experience the same problem ?
    Do you use the Today window in AutoCAD 2002 ?
    What do you have system variable ProxyWebSearch set to ?
    Do you have an internet connection ?
    Do you run Anti-Virus software ?
    Plus, ID: TS64664 - Troubleshoot software conflicts with operating system or other applications
    Have a good one, Mike
    2005-12
    24
    I am making AutoCAD 2006 look like our 2002. I removed 2002 and currently have 2006 on my mahine. I am trying to reload 2002 so I can make some GUI comparisons.
  1. GS304-2: Preparing AutoCAD Drawings for GIS
    By Autodesk University in forum Geospatial
    Last Post: 2013-05-06, 01:16 AM
  2. AutoCAD 2002 LT & Windows 7 Compatibility?
    By bkimmel in forum AutoCAD General
    Last Post: 2010-09-20, 10:10 AM
  3. AutoCad LT 2002 freezes after Access Code
    By lraivala in forum Networks
    Last Post: 2008-12-03, 05:50 PM
  4. Replies: 7
    Last Post: 2007-01-19, 04:01 PM
  5. Fatal errors using AutoCAD 2002 and Windows 98SE
    By prashantkhedekar in forum AutoCAD General
    Last Post: 2005-12-18, 12:29 AM
