Results 1 to 6 of 6
Thread: Changing cut line color
    2004-12
    South Coast NSW
    188
    Default Changing cut line color
    Is there any way to change the color of cut lines in internal wall layers?
    MB Drafting
    NSW Australia
    All AUGI, all the time Firmso's Avatar
    2006-03
    Here, Still
    549
    Default Re: Changing cut line color
    Quote Originally Posted by mbalsom
    Linestyles (linework)
    Hope this helps
    2003-04
    Chino, CA
    4,754
    override cut styles in the Visibilty dialog box of the view
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2004-12
    South Coast NSW
    188
    Line work does not work on internal lines, but thanks.
    Scott, Override Cut Line Styles, I can get to work on external lines but not internal, and also
    this overrides all walls, I would like to do individual walls.
    MB Drafting
    NSW Australia
    2006-03
    Here, Still
    549
    There isn't any way to do what you are trying to achieve. Either do it Scott Davis' way, and/or linework way. You can Draw lines with colors and align them to your internal lines and lock them using linework to modify thickness and linetype.
    That's it.
    2003-04
    Chino, CA
    4,754
    OK, if for individual walls, try using Filters in Revit 9.0
    (Edit: Just tried using Filters, which works for the outside lines lines, but does not allow the inside lines to be changed)
    Scott D Davis
    Autodesk, Inc.
  1. Replies: 17
    Last Post: 2017-08-01, 01:12 AM
  2. Replies: 0
    Last Post: 2014-05-28, 01:06 PM
  3. Changing color of Xref layers based on color and layer name
    By tuerlinckx_peter862162 in forum AutoLISP
    Last Post: 2013-02-14, 06:46 PM
  4. Replies: 0
    Last Post: 2011-11-30, 05:31 PM
  5. Projection/Surface Line Color Override negates Line Weight
    By nosten in forum Revit Architecture - General
    Last Post: 2008-09-30, 07:57 PM
