Results 1 to 10 of 12
Thread: Extract Dynamic Block Attributes, values change as Block changes
    2006-08
    3
    Question Extract Dynamic Block Attributes, values change as Block changes
    can any one help i an looking at trying to extract the size of a part ie: length, width, thickness using attributes but if i strech the part all the sizes change is this possible if so can someone point me in the right direction
    many thanks
    Dave
    0,0,0 The Origin
    8,570
    Default Re: Extract Dynamic Block Attributes, values change as Block changes
    Hi Dave.
    Attributes only work as part of a block so stretching doesn't work. You would have to apply different x,y,z scales to the block.
    I'm pretty sure you would need some programming (or a dynamic block perhaps) to adjust the attributes to suit.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,102
    Hi Dave,
    Please note I have *moved* this thread from the New Forum Users Forum to this one as I believe it would be better served here.
    Below snippet is from the small print on the Forum General page -
    <snip>
    New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
    </snip>
    Richard
    Forum Moderator
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    Extract meaning you want to extract the attribute data from the .dwg to put into Excel or something?
    If yes, then I suppose you could add separate attributes and set visibility in the block editor accordingly.
    Or extract meaning you want it to display the part size, etc. in the .dwg if you stretch it?
    In this case I would suppose you may want to try using fields attached to the object(s).
    You may even want to try combining fields and attributes...
    100 Club r424andy's Avatar
    2006-01
    In this Chair
    170
    If the dynamic block is set up right you can also extract the properties that have been changed
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by dave.buckberry
    many thanks
    Dave
    use fields in your attributes that are linked to Dynamic parameters. then use the attribute extraction wizard found under tools to create a linked table.
    S&D DB Sharing Forum
    2006-01
    In this Chair
    170
    You dont even need fields or attributes. The properties of the block alone are extractable
    100 Club wroebuck's Avatar
    2004-07
    Chico, CA
    158
    It is possible to set up you blocks and extract the data no matter what the new values are. I personally like to use attributes, with naming conventions. That way if using lisp or vb we can grab the blocks and manipulate the atts how ever we want. You can use the attribute extraction wizard as well. I posted this block in the AutoCAD forums, it is a good example of what I am talking about.
    2004-07
    Chico, CA
    158
    Here is a basic sample of a wall or panel. Most of the attributes are fields, so the user only needs to type in the thickness. Hope this helps.
    Active Member esdeyo's Avatar
    2001-05
    Carthage, MO
    76
    I took information from a dynamic block to fill out a steel bill. see the thread below.
    http://forums.augi.com/showthread.php?t=35499
    I hope this is helpful.
  1. Dynamic block with attributes that display X, Y, and Z values
    By sammyz28 in forum Dynamic Blocks - Technical
    Last Post: 2015-12-03, 05:37 AM
  2. Replies: 1
    Last Post: 2014-06-16, 07:54 PM
  3. How to change dynamic block attribute default values based on block selected?
    By zeirz109180 in forum Dynamic Blocks - Technical
    Last Post: 2013-12-13, 02:20 PM
  4. link dynamic block parameters with block attributes
    Last Post: 2012-06-12, 06:38 PM
  5. Extract data from Dynamic block with attributes
    By mahesh.darekar in forum AutoLISP
    Last Post: 2009-01-24, 04:56 AM
