Results 1 to 6 of 6
Thread: Import and manipulate PDF files in AutoCAD
    ACAD Wish List Administration
    2005-06
    1,920
    Default Import and manipulate PDF files in AutoCAD
    Summary: The ability to import and manipulate PDF files in AutoCAD
    Description: I would like AutoCAD to be able to import PDF files into DWG files out-of-the-box.
    How Used: PDFs are the industry standard for electronic publishing, the digital equivalent of paper plots.Clients often will only transmit files in PDF format and ask that the PDF files be manipulated in AutoCAD.
    Feature Affinity: Other
    Submitted By: Wesley Chin on June 23, 2006
    2006-03
    19
    Thumbs up Re: Import and manipulate PDF files in AutoCAD
    this would be a very useful feature, but given this has been a nearly ubiquitous feature of many other design programs for many years, along with a proliferation of utilities, AutoCADs programmers are clearly fearful of stepping on Adobe InDesign's toes.
    Autodesk has thoughtfully given us those superior, highly accurate export formats like DXB and WMF to work with -- sadly no-one actually uses them. it probably won't happen in AutoCAD's lifetime, but we can only hope.
    Earth
    9,804
    Default Re: Import and manipulate PDF files in AutoCAD
    We use ToolPac to import PDF files into AutoCAD, generally for certain files that are supplied to us in PDF format only (details, standard sheets, etc).
    As a general rule, PDF's are still no better than a PLT file. Even if you do import them, you are at the mercy of the accuracy at which the PDF was generated - not a good idea for design drawings.
    Interesting that you have clients that will "only transmit files in PDF format", but then "ask that the PDF files be manipulated in AutoCAD" -- why wouldn't these clients just send the DWG files. Generally, PDF files are transmitted when the author does not want the drawing edited.
    R.K. McSwain | CAD Panacea |
    2004-07
    Detroit Michigan
    2,508
    What do you mean by manipulate?
    Make changes to the geometry?
    I think that defeats the purpose of a PDF file.
    2011-08
    4,581
    Exclamation Re: Import and manipulate PDF files in AutoCAD
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. 2013: Webinar: CMS for AutoCAD® - Create & Manipulate DSTV files
    By AlexineStrucSoft in forum AutoCAD Structural Detailing
    Last Post: 2013-07-08, 08:11 PM
  2. 2012: How to import STEP files in Autocad 2012 (or later) ?
    By Famaice in forum ACA General
    Last Post: 2013-04-29, 12:10 PM
  3. Manipulate All External Files in One Palette
    Last Post: 2008-06-11, 11:24 AM
  4. Is it possible to import Visio files into AutoCAD 2005?
    By Shizzjr in forum AutoCAD General
    Last Post: 2006-11-15, 04:58 PM
  5. Is AutoCAD 2007 able to handle/manipulate ECW files?
    By kpbh in forum AutoCAD General
    Last Post: 2006-04-17, 01:34 PM
