Results 1 to 10 of 10
Thread: Error when trying to install AutoCAD 2002 on a PC with AutoCAD 2006
    2005-12
    24
    Default Error when trying to install AutoCAD 2002 on a PC with AutoCAD 2006
    Has anyone seen this message while installing AutoCAD 2002?
    The following serial number is invalid:
    00--000000y
    Please try again.
    I am trying to load AutoCAD 2002 on a machine that already has AutoCAD 2006 loaded on it.
    Lance
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Default Re: Error when trying to install AutoCAD 2002 on a PC with AutoCAD 2006
    Quote Originally Posted by lance_lie
    00--000000y
    Please try again.
    Lance
    Looks like it doesn't want you to load an older version after loading the newer version. If you have to have both versions on the same machine, you may have to unload 2006, then load 2002 & add 2006.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    Earth
    9,803
    00--000000y
    Please try again.
    Are you installing from the media or from a network deployment?
    Serial numbers are in the form 000-00000000
    (3 dash 8, no letters)
    R.K. McSwain | CAD Panacea |
    13,656
    Hi Lance
    Please note I have *moved* this thread from the CAD Mgmt. General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    2005-08
    Albania
    423
    It is better you didn't install 2 programmes in a local disk as c:
    Try to install AutoCAD 2002 in the local disk (D.
    In my computer I have installed AutoCAD 2006 & @ AutoCAD 2005 in this way.
    Abilene, TX
    1,181
    Quote Originally Posted by arbenallaraj
    I have 2006 & 2007 on the same drive, with no problems. Main thing is I loaded the 2006 well before the 2007. I also loaded from disks.
    Earth
    9,803
    There is no reason to not install multiple programs on a single drive.
    I have had installed at the same time, on the same drive:
    ABS 2007
    AutoCAD 2006
    LDT 2006
    Revit
    C3D 2006
    C3D 2007
    ...with no problems.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by rkmcswain
    ABS 2007
    AutoCAD 2006
    LDT 2006
    Revit
    C3D 2006
    C3D 2007
    And back to R14 (at least) can also be on the same drive with any of those.
    Earth
    9,803
    Quote Originally Posted by jaberwok
    I'm pretty sure that multiple "AutoCAD 2000" based products (2000, 2000i, 2002) cannot co-exist on the same drive though - hence the reason for "RegMan.Zip" at http://www.manusoft.com/Software/Freebies/Index.stm
    2005-12
    24
    Thanks to all that replied.
    I had to unload AutoCAD 2006, reinstall 2002 and then reinstall 2006. A pain, but it had to be done in that order.
    Lance
  1. AutoCAD 2006 - DText dialog box as per AutoCAD 2002
    By paula.romano in forum AutoCAD General
    Last Post: 2006-04-26, 05:23 PM
  2. Best way to Plot in AutoCAD 2002 to 2006
    By einaras in forum AutoCAD Plotting
    Last Post: 2006-03-13, 12:22 AM
  3. Replies: 3
    Last Post: 2006-01-04, 08:19 PM
  4. AutoCAD 2006 to AutoCAD 2002
    By MikeM4OSU in forum AutoCAD General
    Last Post: 2005-11-21, 09:04 PM
