Thread: add/remove programs only shows programs listed with "A" after ACAD 2002 installation
    2006-08
    3
    Default add/remove programs only shows programs listed with "A" after ACAD 2002 installation
    I have Window XP Professional on a Dell computer and have problems installing ACAD 2002 along with Land Development Desktop. Prior to ACAD installation, I am able to view a complete list of programs in the Add/Remove programs in the Control Panel. After ACAD is installed, I am only able to view all programs starting with "A" and nothing else. If the list is sorted in aphabetical order, only programs starting with "a" will be listed but if sorted by other such as size, I will get a different program listing that is not shown under "sorted by alphabetically order". Microsoft and Dell tech support are not able to help me out. I have reformatted the hard drive several times and have installed other programs successfully with all of the programs showing on the Add/Remove listings until I install Autocad and the problems starts here!
    Can anyone help me here? and thanks for your time!
    Marc
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: add/remove programs only shows programs listed with "A" after ACAD 2002 installation
    You could try this solution in this post "RE: Installing 2000i effects add/remove programs". (I have done this and it does work.)
    Or you may try this download in this post "RE: AutoCAD 2002" (I have not tried the download.)
    2001-12
    St. Louis
    5,407
    Talking Re: add/remove programs only shows programs listed with "A" after ACAD 2002 installation
    Hello Marc, I'm going to move this from the AutoCAD Gallery forum to this one, as I believe it will be better served here. Thanks.
    Quote Originally Posted by marc.griffies
    Marc
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Earth
    9,805
    Marc
    OUCH! Reformatted?
    It's a simple fix, documented here:
    http://forums.augi.com/showthread.php?t=12120
    http://blogs.msdn.com/oldnewthing/ar...26/422076.aspx
    http://www.velocityreviews.com/forum...s-listing.html
    R.K. McSwain | CAD Panacea |
  1. Replies: 5
    Last Post: 2011-12-20, 03:18 PM
  2. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
  3. Windows XP - Installing 2000i effects add/remove programs
    By Todd.Worstell in forum Operating Systems
    Last Post: 2007-03-31, 09:31 PM
  4. AutoCAD 2002 - Long blank space in XP add/remove programs list
    By stephen.p.kimber in forum AutoCAD General
    Last Post: 2006-02-02, 04:12 PM
  5. Replies: 0
    Last Post: 2005-08-25, 08:23 PM
