pls help me bring back my toolbars such as dimension, layer, etc. i only have the menu toolbar when i start my autocad 2006 program
Have you tried dragging and dropping on the Transfer pane of the CUI?
Right click in the toolbar area (but not on a toolbar), then choose the menugroup/toolbar you want to show.Originally Posted by jlizann
R.K. McSwain | CAD Panacea |
nothing happens, i only have the menu toolbar (File, Edit, View, etc.) below the "autocad 2006" title bar.
if I point to the menu toolbar area and right click on it, nothing happens, what should I do. pls. help.....
Try the -TOOLBAR command (note the leading dash)Originally Posted by jlizann
How is your right mouse button configured? Right clicking on a non-used (ie grey) area of the toolbars should bring up the options shopwn above.Originally Posted by jlizann
Unless there are no toolbars displayed at all. In that case, you need to display at least one and dock it using the -TOOLBAR command.Originally Posted by carl_hd_collins
i typed toolbar and CUI dialog box appears, but I dont knopw how I'll go about it, pls help!!!!!!!!!!!!
You didn't read my second message close enough.Originally Posted by jlizann
i tried that already, unfortunately nothing happened...=(
