Thread: Express Tools not working in AutoCAD 2004
    Member bpurdie's Avatar
    2005-03
    Southern Illinois
    22
    Default Express Tools not working in AutoCAD 2004
    I hope I am placing this in the right thread. I am having problems getting the express tools to work in AutoCAD 2004. They are installed but can not get them to load. I have tried to load the application "appload" and also "expressmenu" with no luck. I have verified that they are installed on my drive.
    If somebody else logs in on my computer or I on someone else's, they work. Just when I log in on my computer do they not work.
    Please help before I have to replace my computer due to damage.
    Bill Purdie
    2001-05
    Austin, TX USA
    2,201
    Default Re: Express Tools not working in AutoCAD 2004
    Hi Bill
    Please note that I have move this thread from the Software forum to this one. I believe it would be better suited here.
    Thanks
    Forum Moderator.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Quote Originally Posted by bpurdie
    Bill Purdie
    Check to see if the acettest.fas file is in your support path.
    2001-05
    Austin, TX USA
    2,201
    Bill Purdie
    have you tried typing EXPRESSTOOLS in the command line?
    If that didn't work there sounds like something may be wrong with your profile. Something you can do that will basically reset AutoCAD in you login is to delete the following two folders.
    C:\Documents and Settings\<UserName>\Application Data\Autodesk\<AutoCADVersion>
    and
    C:\Documents and Settings\<UserName>\Local Settings\Application Data\Autodesk\<AutoCADVersion>
    Then when you start AutoCAD up again, these folders will be rebuilt and it will be like when AutoCAD was first installed. Of course you will need to redo all your setting again so you may want to hold off in case someone else has a better option.
  1. Express tools not working in AutoCAD 2007
    By jan.pennabecker in forum AutoCAD General
    Last Post: 2006-09-30, 06:13 PM
  2. AutoCAD 2004 - Lost Express Tools
    By ATait in forum AutoCAD General
    Last Post: 2005-11-23, 10:17 AM
  3. AutoCAD 2004 - Install Express Tools
    By tflaherty in forum AutoCAD General
    Last Post: 2005-06-03, 08:40 PM
  4. Express Tools don't stay loaded in AutoCAD 2004
    By Grumpy in forum AutoCAD General
    Last Post: 2004-08-17, 05:18 PM
  5. Missing Express Tools in AutoCAD 2004
    By bnia in forum AutoCAD General
    Last Post: 2004-07-06, 11:26 AM
