Is there an easy way to make an extended end on a bar joist? (ie...18k1 joists with 16" extended end on 1 side.) Thanks
I did not document it yet, but make adjustments on the Design Rules tab, as seen in the attached. Watch the front view as make adjustments.
Of course, this will be PER style.
Terry
Is there a way to set an extended end for each individual joist? The joist ends vary in length.
Not from what I see. You'll need a style for each extended length.
