Results 1 to 1 of 1
Thread: Scanning accuracy, plus rubbersheeting of images
    2005-11
    11
    Question Scanning accuracy, plus rubbersheeting of images
    Historically, the CAD technician at my company had apparently used measured the scaled distances on the hardcopy alignment sheets and used those measurements to create .dwgs. In a few months we will have access to a large scanning copier. Do you have any recommendations concerning the practice of scanning those alignment sheets, rubbersheeting the images (with Raster Design), and then updating the data on the .dwgs using the points represented in the images? Ideally, we would collect GPS coord. for each and every point, but realistically, I was concerned if the use of the scanned images would really be an improvement in accuracy.
    Thank you for your consideration,
    Keri
  1. 3D Scanning.... wow
    By sfaust in forum Revit - Hardware & Operating Systems
    Last Post: 2008-05-31, 03:49 PM
  2. FYI TIP - Rubbersheeting
    By trconnet in forum AutoCAD Map 3D - General
    Last Post: 2007-09-11, 08:14 PM
  3. Formula of rubbersheeting
    By inue28 in forum Raster Design - General
    Last Post: 2006-05-26, 07:59 PM
  4. Scanning Images for Revit Underlays
    By jcoe in forum Revit Architecture - General
    Last Post: 2005-03-14, 01:03 PM
  5. Transformation/Rubbersheeting project
    By c_rado in forum AutoCAD Map 3D - General
    Last Post: 2004-07-23, 04:14 PM
