Results 1 to 7 of 7
Thread: How can I purge a block definition without using purge command ?
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,706
    Default How can I purge a block definition without using purge command ?
    Like this, but i does not work
    (setq EntName (tblobjname "BLOCK" "MyTemporaryBlock" ) )
    (entdel EntName )
    : ) Happy Computing !
    kennet
    2005-08
    1,043
    Default Re: How can I purge a block definition without using purge command ?
    Maybe make sure that there is no inserts of the block name, and then try to delete it from the block collection. It maybe nested though.
    (defun DeleteBlockDef (BlkName)
    (if (ssget "x" (list (cons 2 BlkName)))
     (prompt "\n There are still inserts of this block.")
     (if
      (vl-catch-all-error-p
       (vl-catch-all-apply
        '(lambda ()
         (vla-Delete
          (vla-Item
           (vla-get-Blocks
            (vla-get-ActiveDocument
             (vlax-get-Acad-Object)
           BlkName
      (prompt "\n Block definition could not be deleted.")
      (prompt "\n Block definition was deleted.")
    (princ)
    2002-05
    1,706
    No, there is no inserts or nested block, just a blockdefinition, so the . . .
    (vla-Delete (vla-Item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-Acad-Object )) ) BlkName ))
    . . .did the trick.
    Thank you very much Tim and
    kennet
    2002-05
    1,706
    BTW
    I have problem with the (vla-get-WhatCanISelectHere
    for example UCS or equals, is there any information in the help document to find it ?
    kennet
    100 Club intergrupocr's Avatar
    2006-02
    116
    It depends of the object, you can try to dump the object to see all the properties that you can (vla-get)
    (vlax-dump-object object T)
    2005-08
    1,043
    You're welcome Kennet. As intergrupocr mentioned, you can do that per object you have. You can look through the help files also, that is where I learned most of the ActiveX controls. Once you're in the help files, get to the Developers Guide. Then you will want to look at the ActiveX and VBA Reference. In there you will have a couple other book type things to select from. If you select the object one, then you will get a list of all the objects, and then when you select on one of them, it will go specific to that one object, and it will show all the properties/methods/events for that object. The only problem is getting the right syntax in lisp. One example is
    (vlax-invoke BlkObj 'GetAttributes)
    Will return a list of all the blocks attributes as objects
    (vla-GetAttributres BlkObj)
    Will return a variant of all the blocks attributes as objects. These come with experience.
    2002-05
    1,706
    Quote Originally Posted by T.Willey
    You're welcome Kennet. . .
    Tank you Tim and intergrupocr, this is still a jungle for me and I have to play a lot more to have the experience.
    kennet
  1. Block the Purge Command?
    By cliff collins in forum Revit - API
    Last Post: 2010-10-13, 03:17 PM
  2. Purge a layer without purge command
    By cadconcepts in forum AutoLISP
    Last Post: 2007-09-24, 06:11 PM
  3. Replies: 4
    Last Post: 2007-04-06, 03:38 PM
