Thread: Dimension and Dimension text alignment when using DVIEW
    2006-08
    27
    Default Dimension and Dimension text alignment when using DVIEW
    I just started working for a new company in the past three weeks and I am having problem I have never seen before. This company is currently using AutoCad 2002 with Autodesk Land Desktop 3. They tend to use the DVIEW Twist command a lot. When using a liner dimension, it does not rotate vertical or horizontal as the screen appears when the object is twisted. It makes the dimension aligned with the original coordinates before I twisted the object using DVIEW.
    Is there a way I can fix this? Is there a setting where the dimensions work off of the current view of the object? I am stumped here and getting frustrated. Any help is appreciated. Thanks....
    Frank
    2005-07
    2,356
    Default Re: Dimension and Dimension text alignment when using DVIEW
    Can you not just use aligned dimensions?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by fmertz.118882
    Frank
    Just to clarify - Dview\Twist does not affect your geometry; it just alters your view of it (like twisting your head sideways whilst looking at something).
    You could create a new UCS with the UCS\View option before adding notes (I'm not certain what will happen with the dims though).
    13,656
    Hi
    Maybe...
    Dimensions and Rotated viewports
    Have a good one, Mike
  1. Dimension Text to OUTSIDE of Dimension Line
    Last Post: 2015-09-09, 05:26 AM
  2. Multiple dimension values in dimension text
    Last Post: 2009-02-08, 12:54 AM
  3. dimension text aligned w. dimension lines
    By soender in forum Revit Architecture - General
    Last Post: 2008-04-07, 02:50 PM
  4. Replies: 2
    Last Post: 2007-04-17, 03:08 PM
  5. Replies: 11
    Last Post: 2006-11-13, 01:08 PM
