Thread: Offset creation order
    2002-08
    Phoenix, AZ
    44
    Default Offset creation order
    We just upgraded to 2006 and I am finding that when you offset an oject (line in this case) it keeps the creation order of the source line. Is there a variable or option to turn this off?
    0,0,0 The Origin
    8,570
    Default Re: Offset creation order
    Quote Originally Posted by dburt.37238
    Hi David.
    Would you explain further?
    2001-12
    St. Louis
    5,408
    Question Re: Offset creation order
    do you mean like the 'bring to front' 'send to back' sort of thing?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    13,656
    Hi
    If I am understanding correctly ( highly unlikely ), try the following thread...
    Object sorting - where did it go?
    Plus, maybe look at the system variable DrawOrderCtl
    Have a good one, Mike
    2002-08
    Phoenix, AZ
    44
    Quote Originally Posted by Mike.Perry
    Hi
    This was it, thank you all for your replys.
  1. 2011: label points at an offset from alignment showing stat, offset, and description
    By mw156 in forum AutoCAD Civil 3D - Survey
    Last Post: 2016-09-29, 06:10 PM
  2. Replies: 4
    Last Post: 2015-01-29, 04:46 PM
  3. 2012: New to MEP -need help with conduit offset creation!
    By Sean Kilburn in forum AMEP General
    Last Post: 2012-12-29, 06:44 PM
  4. 2011: Circuit Tag Display Order by Creation??
    By Revit MEP DR in forum Revit MEP - General
    Last Post: 2011-11-29, 04:57 PM
  5. oject creation and draw order.
    By clintonc in forum AutoCAD General
    Last Post: 2008-08-08, 11:20 PM
