Does anyone know of a way to extract a custom linetype to a .lin file? You can pull it from DesignCenter, but that doesn't help if you want to modify the linetype.
Any suggestions? Thanks.
There is a lisp routine that I have used before from Cadalyst that worked. You need to be registered to be able to download.
http://new.cadalyst.com/code/tips/Co...il.cfm?ID=1076
Thanks Glenn.Originally Posted by Glenndp
Hi
Plus, the following threads might be of some help...
exporting linetypes
Linetype edit without the original .lin file
Have a good one, Mike
