Thread: Pulish doesn't work
    2005-01
    185
    Default Pulish doesn't work
    Ok, I try using the Publish command and use the same page setups that I use when plotting straight from the pltter dialog box, it works great from the plot command, but when I try to use the Publish command I get that it could not find the device, everything is the same but the command, suggestions?
    2002-09
    Madison, WI
    4,440
    Default Re: Pulish doesn't work
    Are you using the same page set up? If you can get it to plot from the plot command, you can import/apply that to the sheet set you have set up in the publish command. What type of plot device are you trying to use?
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. DYN doesn't work
    By geohutto520336 in forum AutoCAD LT - General
    Last Post: 2012-02-04, 07:28 PM
  2. YES or NO to all doesn't work???
    By csmac2004 in forum Productstream - General
    Last Post: 2009-03-03, 05:31 PM
  3. Specify New Work Plane - doesn't work?
    By bnelson.188587 in forum Revit Architecture - General
    Last Post: 2008-07-24, 04:50 PM
  4. Publish to 3d DWF - doesn't work
    By dlampley.41310 in forum ACA General
    Last Post: 2007-04-06, 03:36 PM
  5. Just in case 8.0 doesn't work???
    By rookwood in forum Revit Architecture - General
    Last Post: 2005-04-27, 08:11 AM
