Results 1 to 10 of 14
Thread: ADT2007 - Activate a floating viewport inside a viewport
    2005-07
    2,354
    Question Activate a floating viewport inside a viewport - 2007
    In previous releases (upto 2006) if I had a floating viewport inside another floating viewport I used to be able to double click inside one of then to activate it and then press ctrl+R to switch between active viewports.
    This no longer works in 2007 - why have they changed it?
    2005-07
    2,354
    Question Re: ADT2007 - Activate a floating viewport inside a viewport
    Having investigated further it should still work in 2007, I am now guessing a sysvar is the culprit, any ideas .......... anyone?
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,843
    Default Re: ADT2007 - Activate a floating viewport inside a viewport
    Quote Originally Posted by Steve.Sanderson(UK)
    No access to ADT 2007 right now, but check the CUI to see if CTRL+R has been assigned to something else.
    David Koch
    2005-07
    2,354
    No its not, its only recently been installed. Another thing is when I just press the ctrl button by itself the cross hairs change to the pick box (but can pick anything) this doesn't happen on 2006.
    100 Club cholmes's Avatar
    2003-02
    Omaha, NE
    198
    Same thing is happening here with ADT2007.
    The help file says to use CTRL-R, but it's obviously not correct.
    2005-07
    2,354
    Quote Originally Posted by cholmes
    See its not just me (thought I was going mad), this either has to be a setting somewhere (although I haven't messed with anything) or its a bug.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    It seems, for whatever reason, CTRL+R was left out of Shortcut Keys in the stock menu. If you create a command (say ChVP) and use ^V as the macro, you can assign it to CTRL+R in the shortcut keys to return the functionality.
    Apparently ^V doesn't execute "insert" (still works to change viewports) in a macro. I have tested it, and it worked for me.
    HTH
    Tim Creary
    S&D
    DILLIGAF
    100 Club red2002yzfr1's Avatar
    2002-04
    Allentown PA
    141
    Did anyone figure out why the ctrl+r is not working in ADT07. A colleague and I are having the problem of it not working. The only thing that is happening is the cross hairs are changing to a pick box like previously stated.
    2002-04
    Allentown PA
    141
    I went out to Autodesk Knowledgebase and did there fix for this 2476435 in following these steps, it fixed the CTRL+R issue. The trick is to make sure you get the command from the "ACAD" file and not from the "ADT" file.
    2002-02
    Kansas
    482
    I just check of my ADT 2007 it it did not work.
    I use the CUI to add in the CTRL+R to the shortcut key see attach PDF
    Note:
    update to 2011
    I am using ADT 2007 08/06/2008
    PS. If you use any Code I post or Down Load Attachment I would like to know if it was helpful. So please post reply to this thread, on how you use the code or down load. Thank You
  1. No contour of floating viewport
    By j.aaij in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-03-12, 02:36 PM
  2. Zoom extents automatically when you activate a viewport
    By gdaniels in forum AutoCAD General
    Last Post: 2007-03-15, 10:06 PM
  3. Replies: 9
    Last Post: 2007-01-16, 03:35 PM
  4. Able to Pan only so far within Floating Viewport
    By jeff.garr in forum AutoCAD General
    Last Post: 2006-06-20, 06:14 PM
  5. Ability to turn OFF X-Clip command inside a Floating Viewport?
    By bpurdie in forum AutoCAD Customization
    Last Post: 2006-03-16, 07:24 PM
