Thread: Stacked Wall Misbehavior
    I could stop if I wanted to rkitect's Avatar
    2006-01
    449
    Default Stacked Wall Misbehavior
    I have a stacked wall that I'm 'breaking up' in order to attach it to a gabled roof. When I break it up, it deletes a door and the sweeps on the bottom stack flip orientation (so the sweeps are suddenly on the gyp brd side of the wall.
    Any ideas as to what is going on here?
    TIA,
    _Carl
    2006-01
    449
    Default Re: Stacked Wall Misbehavior
    Ok.. even stranger is this.. I tried out of curiosity to see what would happen if I just attached the wall to the roof... and it worked fine. What is the normal behavior of a stacked wall supposed to be when attached to a roof? Ever since I started trying this the bottom wall assembly always ended up attaching to the roof completely eating the top assembly.
    TA
    _Carl
    2004-06
    Memphis TN area
    6,700
    yet another reason why I won't touch stacked walls with a 37.5 ft. pole It just makes for too many headaches, EVERY time I have tried using them in a project.
    AERC, PLLC
    Hernando, Mississippi
    All AUGI, all the time Firmso's Avatar
    2006-03
    Here, Still
    549
    Quote Originally Posted by patricks
    You just have to think like a builder when Modelling with Revit.
    I don't think anyone would want to stack walls. Not even if you have a 100 foot pole to work with.
  1. Stacked Wall Join and Host Wall Sweep Problems
    By residarchitect in forum Revit Architecture - General
    Last Post: 2011-08-08, 09:57 PM
  2. Stacked Wall Type Mark... or should I stick to Basic Wall?
    By sradley in forum Revit Architecture - General
    Last Post: 2008-12-23, 02:30 PM
  3. Stacked wall or curtain wall approach
    By m.thomas in forum Revit Architecture - General
    Last Post: 2006-06-16, 03:49 PM
  4. Changing a Normal Wall to a Stacked wall... Disappears!!!
    By aashley21 in forum Revit Architecture - General
    Last Post: 2006-03-16, 08:17 PM
