Thread: Xref unresolved in AutoCAD 2000?
    2004-08
    137
    Unhappy Xref unresolved in AutoCAD 2000?
    I have Cad 2000 at work I have 2007 I copied a dwg in 2000 that has xref. All xrefs have reloaded expact one. The xref that didnt reload is the heart and soul of my dwg. each time I try to reload the xref says "unresolved".
    Any ideas?
    13,656
    Default Re: Xref unresolved in AutoCAD 2000?
    Hi "sherflor" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    13,656
    Question Re: Xref unresolved in AutoCAD 2000?
    Quote Originally Posted by sherflor
    Hi
    Have I got the following correct...
    * You are using AutoCAD 2000.
    * The unresolved Xref was / is a drawing file from AutoCAD 2007.
    If yes, in what DWG format is the drawing file from AutoCAD 2007 saved in ?
    If no, please explain some more.
    If it turns out, you just need to save the drawing file from AutoCAD 2007 into a lower DWG version ie DWG 2000 format, and you do not have access to AutoCAD 2007, you could simply use DWG TrueConvert from Autodesk ( a direct link to the DWG TrueConvert download page can be found HERE ).
    Have a good one, Mike
    Earth
    9,803
    Any ideas?
    Did you use eTransmit to package this drawing?
    Is the unresolved xref even present?
    When you "reload", are you changing the path?
    What is the path set to?
    Is this "unresolved" drawing in the same directory as the parent drawing?
    Is the "unresolved" drawing in a format that r2000 can open?
    See also: http://support.autodesk.com/getdoc.asp?ID=TS22405
    R.K. McSwain | CAD Panacea |
  1. 2012: Problems in autocad 2012 when opening files from autocad 2011 saved as 2000
    By debora.fernandes in forum AutoCAD General
    Last Post: 2012-06-30, 02:12 PM
  2. Unresolved Xref
    By asmckee in forum AutoCAD General
    Last Post: 2010-03-19, 06:52 AM
  3. Replies: 6
    Last Post: 2009-06-01, 07:10 AM
  4. xref unresolved
    By crbickel in forum ACA General
    Last Post: 2007-03-28, 12:12 AM
  5. Unresolved Xref
    By Shizzjr in forum AutoCAD General
    Last Post: 2005-12-19, 05:17 PM
