Results 1 to 8 of 8
Thread: Text comes in at wrong angle from routine accessed via company menu
    2005-02
    46
    Question Text comes in at wrong angle from routine accessed via company menu
    Was wondering if someone could figure this out. There is a button on this companies menu that work like this. Hit the button and this will insert a thermostat symbol (circle), next it ask to type in text for symbol (T), then it ask to pick the center of the circle and the text which is just a standard text pops in. The problem is the text comes in at a 4.5 degree angle which is wrong, should come in at 0 degree's. If you use dtext or mtext the text works fine. It only happens in one dwg. I didn't know if there were some variables I check or something. Thanks for your help if you respond to this. I don't have access to there menu, I would use something much easier.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Text comes in at wrong angle from routine accessed via company menu
    One thought: is the UCS rotated?
    if that's not it, could you post the macro so we can see if it's something in there?
    Tim Creary
    S&D
    DILLIGAF
    2005-02
    46
    The ucs is not rotated. This is a lisp routine in the companies menu that i can not access. the only way they could fix it was to set up another dwg. I saved this one so i could try to fine out the problem.
    2005-02
    46
    its like something had corrupted the drawing.
    2001-03
    13,499
    Quote Originally Posted by timcreary
    Hi
    Second thought...
    SnapAng is set a value greater than 0 ( Zero ).
    Have a good one, Mike
    2001-03
    13,499
    Hi
    <SNIP>
    My email is < Personal contact information removed. >
    Hi
    I personally recommend that you edit your above post and remove your personal contact numbers ( unless you are 100% happy about giving out such information publicly ).
    You might also want to review "Forum Security" which can be found in the "AUGI Forum Guidelines".
    Thanks, Mike
    Forum Manager
    I could stop if I wanted to sschwartz's Avatar
    2005-04
    Oakland County, Michigan
    424
    Here's a thought: What about the text style?? Maybe the oblique angle is off. Don't they have an IT or CAD person to ask??
    2005-02
    46
    I let the cad manager know. He's a little busy right now. None of the above solutions were the problem.
  1. Company standard text vs civil3d text
    By Mantisguy in forum AutoCAD CUI Menus
    Last Post: 2011-12-16, 10:38 AM
  2. Wrong line angle
    By harilalmn in forum AutoLISP
    Last Post: 2010-10-19, 01:45 PM
  3. Replies: 3
    Last Post: 2007-01-19, 02:34 PM
  4. Wrong screen menu - how do I switch?
    By hodgesgroup in forum AutoCAD Customization
    Last Post: 2005-03-14, 07:03 PM
  5. Menu compiling to the wrong folder
    By LanceMcHatton in forum AutoCAD Customization
    Last Post: 2004-12-23, 03:10 PM
