Results 1 to 9 of 9
Thread: HOW TO CREATE SPANISH ROOF TILE MODEL PATTERN
    2002-01
    3
    Default HOW TO CREATE SPANISH ROOF TILE MODEL PATTERN
    Does anyone know how to create or have an Spanish roof tile model pattern? I can't find one in my library and if I import the one from AutoCAD it won't work as a model fill. Any Ideas?
    2006-07
    California
    115
    Default Re: HOW TO CREATE SPANISH ROOF TILE MODEL PATTERN
    I believe one of the guys on this forum created a pattern of the sort...I'll try to find it.
    2006-07
    California
    115
    Did you check the RUGI site? I believe they have a Spanish Tile pattern you can download. I took the Spanish Tile pattern I had in AutoCad and pasted it into the revit.pat file.
    Or you can do an advanced search of this forum & there are tuns of spanish tile pats
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    You just need to convert your .pat file to a model by adding the following code infront of it, see the revit.pat file for the explanation.
    ; The name may contain any ASCII characters except for comma. They are shown in the list of
    ; imported patterns. The comma and comment are optional. They are ignored by Revit. The header
    ; may be followed by one of the following type directives:
    ; ;%TYPE=DRAFTING or
    ; ;%TYPE=MODEL
    ; If neither directive is present, Revit assumes that it is a drafting pattern.
    Here are all of my .pat files, there are many spanish tiles to chose from, some are in the acad.pat files and have allready had the %TYPE=Model added to them.
    Scott D. Brown, AIA
    BECK
    2002-01
    3
    THANKS, IT HELPED ME A LOT
    2013-04
    3
    Hi Scott,
    Could you write the steps how to import .pat to revit and the next steps to use it as a pattern for roof tiles.
    Thanks
    Nabil Hanna
    2005-07
    Somewhere in the BIM world
    3,792
    Manage - Additional Settings - Fill Patterns
    Click Draftiong or Model depending on the type
    Click New
    Click Custom
    Click Import and browse to Scott's .pat file
    Now it's available to use anywhere
    2013-04
    17
    Quote Originally Posted by sbrown View Post
    ; ;%TYPE=MODEL
    Thanks for putting these together, is there a graphic someplace to indicate what each one is, since there is no preview available for .pat files... rather you have to load them all and apply them to see what they look like (or if you know another way?)
    Thanks
    JP
    Member Poch2020's Avatar
    2016-02
    Philippines
    5
    Smile Re: HOW TO CREATE SPANISH ROOF TILE MODEL PATTERN
    Quote Originally Posted by dhurtubise View Post
    Click New
    Click Custom
    After that, what's next? How do I apply that in my roof element as a pattern? I am using the latest Revit 2018 version.
    Thanks in advance
  1. Spanish Tile Roof
    By Scott Hopkins in forum Revit - Rendering
    Last Post: 2018-02-24, 04:32 AM
  2. Spanish tile hatch pattern - roof plan
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2009-12-11, 12:54 AM
  3. Mission Tile Roof Model Pattern
    By SCShell in forum Revit Architecture - General
    Last Post: 2005-04-14, 05:07 PM
  4. spanish barrel tile roof jpg needed
    By bud in forum Revit Architecture - General
    Last Post: 2005-03-09, 08:07 PM
  5. Spanish Tile Drafting Pattern
    By ariasdelcid in forum Revit Architecture - General
    Last Post: 2004-03-09, 12:08 AM
