Does anyone know how to create or have an Spanish roof tile model pattern? I can't find one in my library and if I import the one from AutoCAD it won't work as a model fill. Any Ideas?
I believe one of the guys on this forum created a pattern of the sort...I'll try to find it.
Or you can do an advanced search of this forum & there are tuns of spanish tile patsDid you check the RUGI site? I believe they have a Spanish Tile pattern you can download. I took the Spanish Tile pattern I had in AutoCad and pasted it into the revit.pat file.
You just need to convert your .pat file to a model by adding the following code infront of it, see the revit.pat file for the explanation.
; The name may contain any ASCII characters except for comma. They are shown in the list of
; imported patterns. The comma and comment are optional. They are ignored by Revit. The header
; may be followed by one of the following type directives:
; ;%TYPE=DRAFTING or
; ;%TYPE=MODEL
; If neither directive is present, Revit assumes that it is a drafting pattern.
Here are all of my .pat files, there are many spanish tiles to chose from, some are in the acad.pat files and have allready had the %TYPE=Model added to them.
Scott D. Brown, AIA
BECK
Hi Scott,
Could you write the steps how to import .pat to revit and the next steps to use it as a pattern for roof tiles.
Nabil Hanna
Manage - Additional Settings - Fill Patterns
Click Draftiong or Model depending on the type
Click New
Click Custom
Click Import and browse to Scott's .pat file
Now it's available to use anywhere
