Results 1 to 9 of 9
Thread: StartUp issues with 2006
    Member kperry's Avatar
    2005-08
    Bridgewater, NJ
    8
    Exclamation StartUp issues with 2006
    Worked yesterday, now I get this:
    C:Program FilesAutodesk Land Desktop 2006admapfdoenabler.arx cannot find a
    dll or other file that it needs.
    C:Program FilesAutodesk Land Desktop 2006AcMapWorkspace.arx cannot find a
    .Failed.
    admapfdoenabler.arx Load Failed
    AcMapWorkspace.arx Load Failed
    Loading AEC Base...
    Loading AEC Base UI...
    Loading AecCMapCogoCmds...
    Loading AEC Project Base...
    Loading AEC Base GUI...
    Loading AEC Schedule Data...
    Loading AEC Utilities...
    Loading AEC Layer Manager...
    Loading AEC Architectural Base...
    Loading AEC Project UI...
    Loading AEC Schedule...
    Loading AEC Object Explode...
    Loading AEC Recipe Base...
    Loading AEC Detail UI...
    Loading AEC Detail Base...
    C:Program FilesCommon FilesAutodesk SharedGISFDO2.0OracleSysAdmin.arx
    cannot find a dll or other file that it needs.
    Help! I can only open CAD once, then have to restart if session closes.
    100 Club MMccall.83699's Avatar
    2005-03
    a little off center
    140
    Default Re: StartUp issues with 2006
    Hey Kate,
    If you haven't solved this already ... you'll probably get a response to this if you post it in the land desktop forum, either here in Augi or in the Autodesk users forum. (<-- more active community)
    2001-12
    St. Louis
    5,407
    Talking Re: StartUp issues with 2006
    I might be inclined to disagree... it was posted in the C3D forum, so I'm assuming that is what Kate is using, and so assume that LDT is mentioned for its object enabler(s)?
    If I am reading the program in question wrong, please post a correction, and one of the moderators will move the thread (please do not repost in another forum on augi.com).
    Quote Originally Posted by MMccall.83699
    Hey Kate,
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2005-08
    Bridgewater, NJ
    8
    Yes, it is C3D.
    2005-03
    a little off center
    140
    Well, color me stupid for mis-reading the post. In my defense, I was led astray by the *Land Desktop* in the error message and assumed it was a LDT2006 loading error and not a C3D 2006 object enabler loading error .... and further assuming that Kate was still using LDT as the last file I got from Kate's company was in LDT.
    So, not that this thread is getting some attention, what's the solution? Reload the ldt06 object enablers?
    2005-08
    Bridgewater, NJ
    8
    Yup, I'm the Guinea pig for upgrading to 2006. (Took us long enough...lol)
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    It is probably a pathing issue. THIS may help. Post back if not.
    2015-11
    86
    I had posted this issue in the wrong forum, so you can ignore the one I posted above. I tried the link from Tim and that cleared up most of the problems I was having. I still get this one though:
    Initializing....
    C:\Program Files\Autodesk Civil 3D 2006\admapfdoenabler.arx cannot find a dll
    C:\Program Files\Autodesk Civil 3D 2006\AcMapWorkspace.arx cannot find a dll or
    .Failed.
    If anyone has any suggestions or ideas, I'm all ears.
    Lost
    1,473
    It may be that there are more path issues besides what was included in that one link.
    Maybe have a look at THIS and THIS and see if it clears things up.
    HTH
  1. misspelled command issues upon startup
    By cwjean76 in forum AutoCAD General
    Last Post: 2010-09-13, 09:21 PM
  2. Replies: 3
    Last Post: 2006-12-26, 03:59 AM
  3. AutoCAD 2006 Set a variable at startup
    By Mlabell in forum AutoCAD Customization
    Last Post: 2006-06-13, 01:56 AM
  4. Cadjet 2 driver issues w/ AM 2006
    By jerodh in forum AutoCAD Plotting
    Last Post: 2006-02-15, 06:35 PM
  5. Added LISP and ARX files to my startup suite in AutoCAD 2006, now I see...
    By sid.fontenot550 in forum AutoCAD Customization
    Last Post: 2005-09-21, 02:24 AM
