Will this work? Please notice the two lines that need editing about the middle of the routine.
(DEFUN C:ADJUSTZ (/ CNT ENTITY PNT SS1 ZELEV ASC FIND_ATT )
;;; retrieve assoc data from entity
(defun ASC (ELEMENT ENTITY /) (cdr (assoc ELEMENT ENTITY)))
;;; Third Party Routine
(DEFUN FIND_ATT (E TAG / FOUND) ; begin FIND_ATT
(IF E ; check for existence of ENAME
; is selected object a BLOCK
(IF (= (CDR (ASSOC 0 (ENTGET E))) "INSERT")
; does it contain ATTRIBUTES
(IF (= (CDR (ASSOC 66 (ENTGET E))) 1)
(PROGN ; loop til correct ATTRIBUTE
(WHILE (NOT FOUND)
(IF E ; do not use an entget unless you have an entity
(PROGN
(IF (= (CDR (ASSOC 2 (ENTGET E))) (STRCASE TAG))
(SETQ FOUND T) ; break loop if found
(SETQ E (ENTNEXT E))
; if not correct ATT get next ATT
) ;end if
(IF FOUND ; return ename if found
E
) ;end if
) ;end progn
(PROGN ; if no match, tell me
(PRINC "\nNo matching attribute found.")
(SETQ FOUND T)
; break out of while loop by faking it out
NIL ; return nil if not found
) ;end progn
) ;end if
) ; end while
) ; end progn
(PROGN ; if no ATTR, tell me
(PROMPT "\nBlock has no ATTRIBUTES ")
NIL
) ;end progn
) ; end if
(PROGN
(PROMPT "\nNot a block ") ; if not a block, tell me
NIL
) ; end progn
) ; end if
(PROGN
(PROMPT "\nNothing selected ") ; if nothing selected, tell me
NIL
) ;end progn
) ; end if
;;; Set Attribute Name
(SETQ ATTRIBNAME "ZC")
(SETQ SS1 (SSGET '((0 . "INSERT")
(2 . "X") ;<-Adjust Block Name here
(IF SS1
(PROGN
(SETQ CNT (SSLENGTH SS1))
(REPEAT CNT
;(WHILE (NOT (SETQ ENTITY (ENTSEL "\nSelect X block: "))))
(SETQ ENTITY (ENTGET (SSNAME SS1 (SETQ CNT (1- CNT))))
PNT (ASC 10 ENTITY)
(IF (VL-STRING-SEARCH
"X"
(VLA-GET-EFFECTIVENAME
(VLAX-ENAME->VLA-OBJECT (ASC -1 ENTITY))
(SETQ ZELEV (FIND_ATT (ASC -1 ENTITY) ATTRIBNAME)
(IF ZELEV
(SETQ ZELEV (ASC 1 (ENTGET ZELEV)))
(IF (NUMBERP ZELEV)
(SETQ PNT (LIST (CAR PNT) (CADR PNT) ZELEV))
(SETQ PNT (LIST (CAR PNT) (CADR PNT) (ATOF ZELEV)))
(SETQ ENTITY (SUBST (CONS 10 PNT) (ASSOC 10 ENTITY) ENTITY))
(ENTMOD ENTITY)
