Results 1 to 6 of 6
Thread: Electrical Symbols
    Member Chirag Dedhia's Avatar
    2005-05
    Mumbai, India
    37
    Arrow Electrical Symbols
    We are creating Electrical Fixtures. These fixtures are 2D and must be visible only in the views that they are placed in.
    Assuming that i'm making copies of the floor plan to do different electrical layouts of the same floor level, i need Data&Voice fixtures in one view and Raw Power fixtures to be visible in another.
    But even on using Symbolic Lines in the Family for these fixtures, i'm able to see the fixtures in all the views that are duplicated from this floor plan. Can there be a way, where we can restrict the fixture to some views only?
    2005-04
    Saintlouis Missouri
    529
    Default Re: Electrical Symbols
    Open up a new Electrical Family Template and make what you want for 2d symbols. Save them in a seperate Electrical Folder so you know that they are only 2d. Load them in your project and then you can hide them from the VG Overides. These also do not show up on your 3d Views, just the plan you put them in.
    100 Club jcdecastro's Avatar
    2006-03
    113
    Make sure you have object styles in each component. The data and voice component should have a data and voice object style, likewise the power should have its power object style and the symbolic lines you draw should be using the respective style.
    Then those styles will show up as subcats under Electrical Fixtures in the project.
    Use View Templates to keep your visibility settings consistent for each plan type.
    All AUGI, all the time mlgatzke's Avatar
    2003-05
    Ankeny, Iowa, USA
    761
    This file contains many of the usual residential electrical symbols (I believe for 1/4" scale) as well as a legend for the sheet.
    All AUGI, all the time Roger Evans's Avatar
    2003-05
    South Wales UK
    828
    UK Electric Symbols
    I find I need a variety of scaled symbols mainly 1:100 & 1:50
    The symbols in the library are drawn 1:50 (1/4")
    Is there an easy way of getting the symbols to automatically select to the appropriate scale of the drawing ie scale to 1:100 (1/8") ???
    Cheers
    2003-05
    Ankeny, Iowa, USA
    761
    Quote Originally Posted by Roger Evans
    UK Electric Symbols
    Cheers
    If you're trying to use my library, go into the families of each symbol and use the resize feature on the top toolbar. These can only be changed in the family - that I know of.
  1. 37 2D Electrical Family Symbols for Electrical Plans
    By residarchitect in forum Revit Architecture - Families
    Last Post: 2017-03-27, 05:18 AM
  2. Electrical Symbols
    By jack209449 in forum Dynamic Blocks - Sharing
    Last Post: 2013-02-13, 12:48 PM
  3. 2012: Tag as Electrical Symbols
    By Limbatus in forum Revit Architecture - General
    Last Post: 2012-05-02, 06:08 PM
  4. Electrical symbols?
    By tjhernacki in forum Revit Architecture - General
    Last Post: 2007-06-22, 02:56 AM
  5. Electrical Symbols
    By Chirag Dedhia in forum Revit Architecture - General
    Last Post: 2006-08-23, 07:09 PM
