Is is possible to change the list of available line widths in the Layer Properties Manager?
(BMP file attached)
(BMP file attached)
I wish.................then I could set AutoCad to ignore all lineweights and not let
the user to assign any.
HiOriginally Posted by pmedina
As far as I know, no ( same information as Robert gave in above post ).
I assume you are aware you can Edit Lineweights with Plot Style Tables...
AutoCAD Online Help File [F1] -> STYLESMANAGER Command -> Edit Lineweights Dialog Box
Apologies if the above is teaching you to suck-eggs.
Have a good one, Mike
the only way i found is through the plotstyles. Go to the page setup manager -> Modify -> Assign plot style table and edit that - below you have a button edit lineweights
Thanks to all.
