Thread: Pyramid skylight on the fly!
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Default Pyramid skylight on the fly!
    Hi there,
    Well, as usual, I was running late on a design for an entry canopy structure remodel for one of my ongoing projects. I was using a bunch of floating "beam-walls" on a grid and wanted to fill some of the openings with pyramid shaped skylights. Lazy as I am clever....here is my latest tip (or trick!):
    Use the basic, 12" generic default roof. Lay it out by footprint with the roof slope toggled on for all 4 sides, set your slope etc; however, once it is the way you want it, edit it as follows:
    Select properties, click "edit" and duplicate it renaming it to "skylight-pyramid" and edit the structure core to 1" thick glass rather than the default 12" and then change the accurender material from "blank" to a glass that you like. Voila!
    This took me all of 1 minute...maybe! How cool is Revit?!
    Hope this helps
    Steve
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Default Re: Pyramid skylight on the fly!
    change it to sloped glazing and you can add mullions, just pick on your pyramid and click properties and in the type pulldown select sloped glazing. then use the curtain grid tool to place the grids.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    2004-01
    Tucson, AZ
    1,272
    Thumbs up Re: Pyramid skylight on the fly!
    Scott,
    Agreed. For a larger one that would be the way to go; however, I was going for a 5' square pre-fab acrylic kinda thing. But thanks for that tip. Many here benifit from these kind of ideas and uses for Revit.
    The only reason I posted this was because of an earlier post about a sloped glazing issue regarding joins and someone responded that they could do a roof or wall and change it to a sloped glazing afterward.
    I love that Revit lets you think "outside of the box".
    This all became very obvious when I read and then explored the whole issue about standing seam metal roofs. I can not remember the individual; however, he posted the thread about changing a sloped glazing system from glass to roof metal and then modifying the mullions to appear as the seams. How cool was that!
    Thanks to everyone who contributes here!!!!
    Steve Shell
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,268
    I've just been playing around with this and the sloped glazing to metal roof works great. I also tried building the sloped glazing over top of a generic roof and then lifting the "metal" roof to the surface. Revit doesn't seem to mind building roofs inside or on top of one another. This could prove quite handy.
    Joe
  1. Zoning Pyramid
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2012-05-02, 04:01 PM
  2. Pyramid Mass
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2010-08-18, 07:17 PM
  3. Void pyramid
    By fabrice in forum Revit Architecture - General
    Last Post: 2009-09-22, 06:35 PM
  4. Help in command for pyramid
    By aml in forum AutoLISP
    Last Post: 2007-10-12, 02:27 PM
