Thread: Xref Layers do not retain their settings in a Viewport
    Member csiress's Avatar
    2005-06
    Orlando, Fl
    28
    Question Xref Layers do not retain their settings in a Viewport
    Within AutoCAD 2005 and '06, I have this drawing which when I go into the view port and freeze or turn off certain layers, they'll reappear when I reopen the drawing. The layers are part of an xref, if that matters.
    Kinda sounds like a specific setting, though.
    Does anyone know how to fix this?
    Thank you.
    Craig II
    Earth
    9,805
    Default Re: Xref Layers do not retain their settings in a Viewport
    Explore the VISRETAIN system variable.
    R.K. McSwain | CAD Panacea |
  1. Publish - Won't retain location settings
    By JHancock in forum AutoCAD Plotting
    Last Post: 2012-04-26, 07:02 PM
  2. Changes to viewport layers revert on Xref reload
    By aswartzell in forum ACA General
    Last Post: 2007-07-13, 04:43 PM
  3. Retain Crop Region Settings
    By iru69 in forum Revit Architecture - Wish List
    Last Post: 2006-01-14, 07:06 AM
  4. Frozen Xref layer(s) in current viewport do not retain their setting
    By linda.s.parsons in forum AutoCAD General
    Last Post: 2005-12-06, 09:47 PM
  5. "Retain changes to Xref layers..."
    By jsr13 in forum AutoCAD General
    Last Post: 2004-11-05, 09:17 PM
