Results 1 to 8 of 8
Thread: Are junk layer filters added?
    Active Member tomdillenbeck's Avatar
    2004-05
    Dearborn, MI
    52
    Angry Are junk layer filters added?
    We get consultant files from different places and in many cases the Layer Properties Manager take forever and a day to open because there are hundreds of layer filters.
    Is there some bug that automatically generates large quantities of layer filters?
    Often there are 5 times the number of filters as actual layers.
    2001-10
    Arizona
    2,337
    Default Re: Are junk layer filters added?
    Yes, it is called AUTOCAD!.
    See this link. http://usa.autodesk.com/adsk/servlet...linkID=2475323
    It is a result of BAD cad practices and programming combined to give you grief.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2001-07
    29
    once the drawing finally comes up delete all the filter and purge the drawing
    should get better
    nick
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,791
    Rober Bell had a lisp to delete all layer filters. Since acadx is down, you can download it from Cadalyst.com. It was in Hot Tip Harry's section.
    C:> ED WORKING....
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,285
    Angry Re: Are junk layer filters added?
    Quote Originally Posted by tomdillenbeck
    I hear you on that one, brother!
    I get this all the time, one I got a couple months back had about 80 layers, but easily 500 layer filters (most of which had no layers in them).
    I couldn't figure out what was slowing the drawing down so much until someone suggested that I look there.
    I deleted them all and everything started behaving normally again.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2004-05
    Dearborn, MI
    52
    Question Re: Are junk layer filters added?
    Quote Originally Posted by mjfarrell
    From looking at this article, it appears to only be an AutoCAD 2002 problem. I can't replicate the problem in 2005, so it must now be fixed. This means we only get this problem from consultants who use 2002. Would anybody disagree?
    2001-03
    13,499
    Hi
    Below snippets are from AutoCAD 2004 reviews -
    <snip>
    Layer Filters Enhancements – The problem with Layer Filters being carried over when a CopyClip is performed between two drawing files has been resolved. This resulted in many problems with a lot of Layer Filters being added to a drawing unknowingly. There is also an additional option in the Layer Filters dialog box to Delete All filters.
    </snip>
    <snip>
    Layer filters are not multiplying on your drawings since they are not following when you insert or pasteclip to a drawing.
    </snip>
    Have a good one, Mike
    Last edited by Mike.Perry; 2005-02-01 at 08:25 AM. Reason: Correct bad formatting.
    I could stop if I wanted to acad's Avatar
    Roanoke, VA
    355
    Has anyone seen any other problems as a result of too many layer filters? I have a user with a zoom problem that she thinks is related to her too many layer filters. I suspect it's really a video problem or a wheel mouse problem. Just thought I'd ask to cover all bases.
  1. layer filters
    By richardronan in forum AutoCAD General
    Last Post: 2009-12-10, 02:28 PM
  2. Layer filters - again.
    By jaberwok in forum AutoCAD Tips & Tricks
    Last Post: 2008-11-27, 10:32 AM
  3. Layer Filters...
    By billynutts in forum AutoCAD General
    Last Post: 2005-06-02, 03:43 PM
  4. Layer Filters
    By cadconcepts in forum AutoCAD General
    Last Post: 2005-01-10, 06:02 PM
  5. Layer filters, anyone?
    By gbrowne in forum AutoCAD LT - General
    Last Post: 2004-07-20, 07:15 PM
