Thread: C3D 2007 install issue
    I could stop if I wanted to Clyne Curtis's Avatar
    2003-05
    Provo, Utah
    208
    Default C3D 2007 install issue
    A buddy of mine is trying to install C3D 2007 on an athlon 64 system with 1 gig ram and running window 2000. It returns the following error message:
    Desktop: Access to specified device, path or file denied
    and then kicks him back to the desktop. He is able to install it just fine on a Pentium 4 system. He has checked anything to do with administrative rights and it all looks fine.
    Any ideas?
    Clyne
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: C3D 2007 install issue
    It has nothing to do with Athlon 64 vs. Pentium 4. I have installed Civil-3D on Athlon 64 chips with no problems.
    It is highly probably that this is an administrative issue with the computer, and has absolutely nothing to do with hardware or Civil-3D. Has he installed any other Autodesk product on this system?
    Active Member bruce.adams's Avatar
    2005-05
    New England
    59
    1) Make SURE they are logged in as an Administrator for their machine.
    2) If their hard drive is NTFS formatted, have them check the Security Properties for drive C: - Make sure it's set to "EVERYONE", not a specific user. The problem is that the "Windows Installer" service runs as a "SYSTEM" user. So if "username" is the only user that has full rights to the drive, then "SYSTEM" cannot fully access it.
    3) Make sure the TEMP folder is set to a valid folder, then CLEAN it out: In Start > Run, type "%temp%", then press enter. If the folder is not found, then they will need to set their TEMP environment variable to a valid folder. If it IS found, then erase all the files out of it.
    4) For more thoughts on that error, search for "ERROR 1321" at http://support.microsoft.com
    Microsoft Knowledge Base Article - 232143
    Q232143 - Various Error Messages When MSI File Creates and Modifies Files and Registry Keys
    http://support.microsoft.com/default...b;en-us;232143
    5) Check to make sure that he's local admin (not inheriting permissions through domain)
    2003-05
    Provo, Utah
    208
    Great suggestions all! Thanks for the assistance!
    Clyne
  1. issue with icons on re-install
    By mhawk in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2011-03-07, 06:10 PM
  2. AutoCAD 2009 Install Issue
    By m_el_mansy2003 in forum AutoCAD General
    Last Post: 2010-02-10, 07:04 AM
  3. Lt 2007 will not install
    By SCROSLEY in forum AutoCAD LT - General
    Last Post: 2007-09-18, 04:25 PM
  4. Re-Install AutoCAD 2007 using a different Company name
    By jhale.77541 in forum AutoCAD General
    Last Post: 2006-06-04, 01:55 PM
  5. TrueView 2007 install errors
    By DarrenYoung in forum DWG TrueView - General
    Last Post: 2006-04-25, 12:14 AM
