According to
http://www.accustudio.com/forum/tuto...nteriors01.htm
this is a very good example of accurender.
Can we use this technique in Revit? HDRI supported?
Can any people help me?
According to
No. You'll need Viz.Originally Posted by kevin.ling
thanks for reply.
does revit using accurender? If so is that any plugins that can use?
we only have revit as a modelling and rendering package.
Revit uses Accurender. However the version embeded in Revit is quite old.Originally Posted by kevin.ling
After fig. 11 it's a useful tutorial if you can translate it to AR in Revit. Revit is perfectly capable of making an image like that.Originally Posted by kevin.ling
Hi Aaron,Originally Posted by aaronrumple
I am hoping they upgrade / improve a rendering engine inside Revit as well as allow external communication for those with a specific need......
I need to have on board rendering but could not justify buying a VRay or Lightworks or whatever million packages there are out there...
What do you think RB10 is likely to provide ?
regards
trombe
