Thread: ???grid lines???
    Member frances.119664's Avatar
    2006-08
    22
    Default ???grid lines???
    my question is:
    how do i only show the inner part of the crop on my 2nd floor plan view.. When I try stretching it in on the 2nd floor plan, the ones on the 1st floor plan stretches in too, but i need the grids on the 1st floor plan to be longer so it goes through the carport.
    how do i do that..
    HELP!!
    thanks.
    2002-09
    Madison, WI
    4,447
    Default Re: ???grid lines???
    I'm not sure on this, but try dragging the grid lines out side the crop box in your floor plan. I believe that this allow you to keep the 4' (Or what ever you have set up) away from the cropped region. Similar to the Level tags. Hope this helps.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    100 Club Jos Arpink's Avatar
    2001-12
    Vancouver BC Canada
    129
    Frances, I think you might be stretching the 3D extent of the grid instead of the 2D extent. Stretching the 3D extent will affect the grid throughout the model, in all views. Stretching the 2D extent will affect only the extent in the current view.
    Select/highlight the grid, you should see an extent control at each end. It'll say 3D or 2D. Just click on the control to switch between them.
    Jos Arpink
  1. Grid lines are 2D & 3D??
    By mattw in forum Revit MEP - General
    Last Post: 2009-11-18, 05:11 PM
  2. Construction Grid Lines and Grid Dimensions..angles columns
    By persianize in forum Revit - Student Support
    Last Post: 2009-01-02, 09:52 AM
  3. Hide Grid Bubbles, but not Grid Lines
    By brethomp in forum Revit Architecture - General
    Last Post: 2007-05-08, 07:46 PM
  4. Grid Head / Grid lines on separate export layer
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-10, 09:02 PM
