Civil 3D 2007 service pack 2 is now available. Be sure to look at the readme file.
http://usa.autodesk.com/adsk/servlet...linkID=3549304
Some excerpts from the readme:
Standard template files (*.dwt) have have been recreated due to issues found with Pipe Network Parts Lists. Some Network parts lists may be corrupt if you use .dwt files from the Autodesk Civil 3D 2007 release. The new template files will be posted at http://civilcommunity.autodesk.com/. (I could not find these Sep 2. I assume they will be posted soon.)
Version 1 of the Google Earth Extension is only compatible with Autodesk Civil 3D 2007 and Service Pack 1 or 1A and will be disabled after you install Autodesk Civil 3D 2007 Service Pack 2. In order to use the Google Earth Extension, after installing Autodesk Civil 3D 2007 Service Pack 2, you must download and install Release 2 of Google Earth Extension.
