Results 1 to 9 of 9
Thread: AutoCAD 2005 - Losing commands, JIT debugging message appears
    All AUGI, all the time Statler's Avatar
    2002-01
    At right angles to reality
    512
    Default AutoCAD 2005 - Losing commands, JIT debugging message appears
    Hi all,
    For some reason I keep loosing some commands most notably the Layer command where I get the JIT screen come up (see attached). I have just done a repair from the ACAD CD.
    The commands sometimes come back but more often I need them and can reset but just closing down and reopening CAD.
    Acad 2005. ( I want 2007)
    Any help would bee appreciated.
    Many thanks.
    Richard
    Some Days it's not even worth chewing through the restraints.
    2006-01
    Land of chocolate
    228
    Default Re: AutoCAD 2005 - Losing commands, JIT debugging message appears
    don't repair - uninstall and reinstall a fresh copy
    2002-01
    512
    I have now reinstalled CAD, and was just on the point of getting back to you to say everything was OK when the layer command stopped working again.
    Just about to get the full problem text and it started working again???
    Is this just in time programme part of Cad or Window?
    Richard
    Houston
    7,520
    What version of .NET do you have installed?
    2002-01
    512
    Quote Originally Posted by rkmcswain
    To be honest I Don't know or now how to find out.
    My little knowledge really begins and end with cad.
    Richard
    Houston
    7,520
    Quote Originally Posted by McDonaldRi
    Try Add/Remove Programs
    2005-08
    Albania
    423
    Hello
    I think you have problems with the windows system .Scan your system and try again to install ACAD 2005.
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, South Carolina
    149
    Hi all,
    Many thanks.
    Have you tried invoking the JIT debugging? It says to see the end of the message (or box or whatever... it's on the bmp) to see how to do that. I'd try that first to see what you get next time.
    Drop me off in Asheville.
    2002-01
    512
    Rick you da man!
    Was just on Microsoft .net framework 1.1
    Have now installed Sp1 for 1.1 and Microsoft .net framework 2 and (fingers crossed) everything seems ok at the moment.
    Richard
  1. JIT Debugging Error Message
    By lonewolfjustin in forum AutoCAD General
    Last Post: 2008-10-23, 06:52 PM
  2. Replies: 5
    Last Post: 2007-05-25, 03:31 PM
  3. MText appears ok in AutoCAD 2005, but messes up in AutoCAD 2007
    By mattj.120434 in forum AutoCAD General
    Last Post: 2007-01-18, 03:03 PM
  4. AutoCAD LT 2005 - Hatch area appears blank
    By jonm in forum AutoCAD LT - General
    Last Post: 2005-02-19, 04:25 PM
  5. AutoCAD 2005 appears sluggish across LAN
    By vtmiii in forum AutoCAD General
    Last Post: 2005-01-21, 12:44 PM
