Thread: listening dimensions...for angles
    Active Member cparsons's Avatar
    2005-09
    San Francisco
    77
    Default listening dimensions...for angles
    Hi all,
    If I want to enter the length of a wall, cool, I get it. How about the length and the angle before I finish the wall?
    Searched through documentation and a bit on AUGI, cannot seem to find it.
    Is the answer out there?
    Chris
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: listening dimensions...for angles
    If, when creating the wall, you leave one end unconnected, you can then highlight the wall and it's angle relative to the connected wall will show, and is editible. Once you've set the angle, you can attach the other end by dragging or trimming...
    2005-09
    San Francisco
    77
    but what if i am drawing my first wall and i know i want it to be 30' and 12 degrees off. Can't I just input that?
    I could stop if I wanted to mibzim's Avatar
    2005-06
    Brisbane, Australia
    260
    I dont think so - this is something i've wanted to do fore ages.
    Would be cool if you could somehow tab through which dimenion you wanted to enter, instead of it always automatically taking the length.
    Drawing a box for example, it doesnt even know which dimenion you are typoing so takes neither!
  1. Joining Channels to Angles sends components skewing at odd angles. (REVIT Struct 2012)
    By Melissa.Gill641991 in forum Revit Structure - General
    Last Post: 2012-05-25, 05:56 PM
  2. Change angles of Mtext to new Angles
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-01-30, 07:03 AM
  3. Construction Grid Lines and Grid Dimensions..angles columns
    By persianize in forum Revit - Student Support
    Last Post: 2009-01-02, 10:52 AM
  4. Listening Dimensions
    By david_peterson in forum Revit Structure - General
    Last Post: 2006-08-29, 04:12 PM
