Thread: How do I send a DST to the Bin
    Member pittman's Avatar
    2002-01
    11
    Default How do I send a DST to the Bin
    I set up a sheet set in a drawing, and have since realized it's worthless (at least at this point in time). I would like to sh!tcan it but if I delete the .dst it comes back as soon as i open the drawing. Any input?
    **EDIT** Ok so apparently the "close sheet set" is not for closing the sheet set manager as it would imply, but in fact it gets rid of the sheet set.
    Active Member tomdillenbeck's Avatar
    2004-05
    Dearborn, MI
    52
    Cool Re: How do I send a DST to the Bin
    That's right. Closing the Sheet Set does not close the SSManager, only one set. I sometimes have multiple Sheet Sets open in SSM because I'm working on different projects. Once I'm done with a job, I close that Sheet Set, but not the SSM because of the current job I'm working on.
    2002-01
    38
    Default Re: How do I send a DST to the Bin
    I did it the old fashoned way.. went into the sheet-set directory thru windows and deleted the dst file I created. Don't know if that was the right thing to do, didn't have anything important associated with it. Check it out first before you do it.
  1. send an alert with .dwl
    By clovis in forum AutoLISP
    Last Post: 2008-03-17, 08:11 AM
  2. Multiple send to back
    By anthonyf in forum Revit - API
    Last Post: 2007-12-05, 07:55 AM
  3. Send Attributes to Access
    By jp_lujan1 in forum VBA/COM Interop
    Last Post: 2006-07-07, 09:02 PM
  4. Send to Back Hatching
    By mflure.80520 in forum ACA General
    Last Post: 2005-01-31, 05:00 PM
  5. We need this for Revit, Send in requests!!
    By david.kingham in forum Revit - Hardware & Operating Systems
    Last Post: 2004-12-17, 04:56 PM
