Take a perspective view of a 3D solids model defined on a 1024 x 768 resolution monitor (aspect ratio w/ Clean Screen is height = 71.4% of width) and display the same view on a 1280 x 1024 resolution monitor (aspect ratio w/ Clean Screen is height = 77.2% of width, making the display more square). To compensate for the more squarish aspect ratio, the view displays more of the model outside of the original view bounds at the top & bottom of the display, without cropping the sides. But Render that same view on the 1280 monitor (Photo Raytrace) to the Model Space non-tiled viewport, and the original view sides are slightly cropped in the rendered image! Is there a way to avoid the cropping?
