Results 1 to 6 of 6
Thread: Can't delete object with delete button
    2005-12
    2
    Default Can't delete object with delete button
    When I select the object, I can't delete the object with delete button in keyboard. I've search in the Help menu, but aahhh it's too many, confusing.. Any solution? Thanx.
    I'm sorry if this thread is repeated.
    13,656
    Default Re: Can't delete object with delete button
    Hi
    Try HERE.
    Have a good one, Mike
    2006-01
    Land of chocolate
    228
    but can you delete it with the autocad command?
    are you able select it at all?? maybe the object is on a layer that is locked
    Earth
    9,805
    Quote Originally Posted by gtx
    Set PICKFIRST to 1
    If the objects layer was locked, it would say so on the command line.
    ...was on a locked layer.
    R.K. McSwain | CAD Panacea |
    2005-12
    2
    Thumbs up Re: Can't delete object with delete button
    Quote Originally Posted by rkmcswain
    Set PICKFIRST to 1
    at least it works!.... many many thanks I'm sorry if the forum is repeated.
    maybe this thread can be included in FAQ thread.
    2015-01
    2
    Thank you
    Its really helpfull
  1. Delete and Delete All Page Setups
    Last Post: 2015-12-17, 06:38 AM
  2. 8.1/E - Delete/Create object styles for imports
    By janunson in forum Revit Architecture - Wish List
    Last Post: 2005-12-21, 03:36 PM
  3. Delete button not working
    By Dpump777 in forum AutoCAD General
    Last Post: 2005-12-07, 09:41 PM
  4. Delete Duplicate Text in the same object
    By ccowgill in forum AutoLISP
    Last Post: 2005-11-22, 11:31 AM
  5. Revit Speaks "Invaild, Inacurrate, Must delete this object!
    By cek in forum Revit Architecture - General
    Last Post: 2005-07-04, 09:54 PM
