I know REVIT web library has some Andersen window families...Has anyone created and French door families? Or know where I can find some?
Thanks!
Thanks!
I have French door families, but I don't believe that they are Andersen specific. I've attached them if you want them.
Hi Sharry.
I use exclusively Andersen product. Here are the doors that I've created so far. I haven't finished the full library because I tend to produce as I go. If you have any questions on using them let me know. I have posted all of my Andersen families at Revitcity.com and as soon as this file exchange is up i'll post them here as well. (I posted them all to RUGI but that is moot at the moment.)
I've made the full casement library--updated further and in more detail than the original library that was produced. I've also begun to modify many of the double-hung windows to my same set of standards and also begun on the Awning windows but don't have much done yet.
Only FWO doors but you can probably modify them to FWH if you like.
Just ask if you need anything else from me!!
RUGI downloads are still available at www.rugi.org/download.htm until the exchange is functional here.Originally Posted by adegnan
(EDIT! Sorry, the bad link has been fixed.....made 'download' plural and that screwed everything up!)
adegnan you the best! thanks! I've created numerous PELLA windows and doors families. Though we tend to vary from project to project depending on the owner...I'll check our rugi...thanks again...
I've also posed some pretty neat 6-panel and 3-panel doors including rough openings and casing to those sites. They are single doors, double pocket doors, and some double doors also. Some of them are also in divided-light and I posted some exterior doors with windows, brickmould, and casing.
The casing profiles are very easy for any of you to swap out for another profile if you prefer.
