jasonb3
Hi Peter,
Thanks for the reply.
I do not seem to be using any other software. I just did a setup on the plotter, and it did not make the rotation any better. I adjusted the setting as in the attached image, and it (the autorotate) is not affecting the plot output at all. (?!?) In fact, I tried several combinations before and after the plot re-config and they're all the same. I just don't know. Does Revit have a plotter driver in the works? This seems to be too simple an issue....there must be a fix.
