Results 1 to 6 of 6
Thread: AutoCAD 2007 - If an image is rotated it plots a green area around the image
    2004-11
    29
    Default AutoCAD 2007 - If an image is rotated it plots a green area around the image
    I am having problems with a file that has a scanned image attached to it. If the image is rotated it plots a green area around the image. I have attached a couple of images of my print results. I did not have this problem in 2006. Any ideas?
    2001-03
    13,499
    Question Re: AutoCAD 2007 - If an image is rotated it plots a green area around the image
    Hi
    When you say "scanned image attached" do you mean...
    * OLE Object.
    * Image attached via ._EexternalReferences or ._ImageAttach commands.
    Does the problem appear when using all output devices or just the odd one or two ?
    How are you Plotting from within AutoCAD - Windows System Printers / .PC3 with Windows Driver / .PC3 with Heidi Driver ?
    Have a good one, Mike
    2004-11
    29
    Default Re: AutoCAD 2007 - If an image is rotated it plots a green area around the image
    The image is attached via the externalreferences. I am assuming that our Richoh printer is using a windows driver. Our plotter is an HP1050c. It appears when plotting to both.
    2001-03
    13,499
    Quote Originally Posted by scott.hillman
    Hi
    What happens if you rotate the image outside of AutoCAD 2007 ie Rotate the image in your chosen imaging software.
    Then attach the pre-rotated image.
    Does it Plot correctly OR does it still Plot with a green area around the image ?
    How is your HP DesignJect 1050C within AutoCAD set-up...
    * Windows Driver.
    * Heidi Driver.
    2004-11
    29
    It looks as though, the HP plotter is using a windows driver. But, it's always been that way. Why start having problems now?
    2001-03
    13,499
    Hi
    That's the million £ question...
    Something has obviously changed or been introduced that is causing the problem / issue... tracking that something down can prove to be the difficult / time consuming part.
  1. AutoCAD LT 2007 - JPG image appears distorted
    By SaraS in forum AutoCAD LT - General
    Last Post: 2007-02-06, 08:11 AM
  2. Image not visible in AutoCAD 2007, but is in 2006
    By gary_pritchard in forum AutoCAD General
    Last Post: 2007-01-02, 10:24 PM
  3. AutoCAD 2007 LT - Image support.
    By CGM in forum AutoCAD LT - General
    Last Post: 2006-12-04, 11:56 AM
  4. Disappearing Image in AutoCAD 2007
    By cadconcepts in forum AutoCAD General
    Last Post: 2006-08-28, 01:54 AM
  5. AutoCAD 2005 TIFF Image files - Image file not valid
    By richard_hamilton in forum AutoCAD General
    Last Post: 2004-09-30, 11:39 PM
