Thread: Unable to Change Baluster Material
    2004-06
    2
    0 Did you find this post helpful? Yes
    Default Unable to Change Baluster Material
    I am unable to change the material of the Baluster in the Railing even though I am able to change the material of Rails. I even tried making a new Baluster and assigning it a Material Parameter and giving it default material. The Material Parameter does not show in the file I put the new Baluster and the material was all different from the one in the family. Also how can I update the already loaded family. Revit does not take the changes in consideration if the family is reloaded.
    Thanks in advance.
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Thumbs up Re: Unable to Change Baluster Material
    If the baluster already had a material setup for it when it was originally loaded. When you changed the material in the family and reload it, it will not update. You can access the materials for balusters in the project be going in the browser, under families, railings and then select the baluster and then edit the material from there.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    2009-12
    Default Re: Unable to Change Baluster Material
    Quote Originally Posted by qetuo_s View Post
    Thanks in advance.
    am also facing the same problem
  1. 2014: Unable to see applied material in 3D rendering of imported DWG
    By ctc in forum Revit Architecture - General
    Last Post: 2014-04-18, 04:33 PM
  2. 2012: how to add material in baluster
    By sudarshankvarma007123670 in forum Revit Architecture - General
    Last Post: 2011-12-07, 07:53 PM
  3. Baluster Material
    By stephanschneller in forum Revit Architecture - General
    Last Post: 2010-06-09, 08:53 AM
  4. Baluster, Baluster - Post and Baluster - Panel
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2009-10-15, 03:27 PM
  5. Baluster material
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2005-03-09, 05:51 AM
