Thread: Is there a way to view the scale of a particular viewport?
    2006-07
    Home
    31
    Default Is there a way to view the scale of a particular viewport?
    Hi there!
    Is there a way that I can view the scale of a particular viewport (in case I have 2 or more viewports in the same layout)?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Is there a way to view the scale of a particular viewport?
    The Viewports Toolbar can display the viewport scale. You should also be able to view the scale in the Properties Palette.
    2006-01
    Land of chocolate
    228
    Also the scale factor is actually your ZOOMFACTOR and that is an autocad command
    Earth
    9,805
    Quote Originally Posted by Buffeldrek
    Incorrect.
    ZOOMFACTOR is a system variable that controls the magnification changes when the mouse wheel moves. It has nothing to do with viewport scaling.
    R.K. McSwain | CAD Panacea |
  1. Replies: 1
    Last Post: 2014-11-04, 03:32 PM
  2. Replies: 0
    Last Post: 2013-11-08, 05:29 PM
  3. Replies: 3
    Last Post: 2013-05-01, 04:50 PM
  4. Viewport scale changes after using Maximise Viewport facility
    By larry.111254 in forum AutoCAD LT - General
    Last Post: 2007-02-21, 12:08 PM
  5. Replies: 0
    Last Post: 2006-11-28, 10:37 PM
